Hey guys-
Quick question for you. I see that you can "burn" a bootable SD to run Honeycomb, Froyo, etc. from the SD without having to install it to the internal memory. Are you still required to root the device if you use this method? Can I pop in the card when I want to mess around with those version of the OS, and simply reboot without the card in to go back to the BN stock OS?
Furthermore, can this also be done using a pre-rooted 1.1 image? I would like to play around with this, but the wife doesn't want me breaking her device.
