Recently purchased a tablet for my son model number WM8850-MID, android version 4.0.3, Kernal version 3.0.8, Build number 4.0.3 ICS
Having problems trying to connect to the Wi-Fi. I have tried switching the router off and on, didn't work.
The other issue is when i connected the tablet to the PC via USB port. It didnt show up as a removable storage.
Any suggestions/help. This is the first tablet so not incredibly clued up but can get by.
Hi folks,
At the end of my tether with this problem. Probably put around 5 hours into it at this point, I'm quite a techie guy, but have not been able to solve the issue with my Allwinner A13 7" tablet and am in need of help.
There is some problem with the internet connection. The play store won't let us register and some apps won't connect. The stock browser brings up a security certificate warning even just going to google.com, but there is no problem when using Firefox. *Just to note I installed Firefox and other apps by downloading apk's from alternative websites.
If anyone has any idea or direct me in some direction I would be very grateful.
Thanks,
Eff
I would try disabling the security in the router, restart it, make certain you can connect unsecured then put the security back in. Also if it's WEP security make certain you change it. I assume since you read my original post that you have tried a channel change and downloaded the app I suggested, (using your neighbor's connection, of course)
