I'm currently working on a project to mount an android tablet into the dash of my 2011 Genesis Coupe. I need to find a tablet with the following features/specs in order to make it work properly...
Necessary:
- 7" screen
- ARM-based processor
- Android Honeycomb or ICS (need all onscreen controls since you wont be able to access the hardbuttons after mounting)
- WiFi
- GPS (real gps not just wifi positioning)
- Bluetooth
- MicroSD card slot
- Relatively normal thickness bezel that is even (some of the tablets that have extremely fat bezels on the one side wont fit behind the dash kit)
- 1/8" audio output
Bonus:
- USB Host port
- IPS Screen
Anyone know of any that fit these requirements? The closest I've found is the Ainol NOVO 7 Elf/Aurora but they are missing the Bluetooth and GPS which are a huge portion of my plans. If I can find one that meets the above specs i'll definitely post pictures/videos of the install and final product!
Thanks!
Necessary:
- 7" screen
- WiFi
- Bluetooth
- MicroSD card slot
- 1/8" audio output
Bonus:
- USB Host port
- IPS Screen
Thanks!
