wireless charging
blacknbluevue
Jun 9, 2014
Hi all
The connection between the male terminal of any cable and the female receptacle is not continuous thus resulting in poor or no charge. I think the problem is with the receptacle in the tablet. Is it a DIY job to replace the receptacle? If not, I think I can skirt around the problem by using a wireless charging pad. Is this tablet able to make use of one and is there a preferred pad to use?
David
leeshor
6,329
1,037
Unless the tablet was designed for wireless charging it won't be an option. That tech was designed for phones or a phone that has a removable back. Not sure about the port replacement. The trick may be actually finding one that was designed for your tablet.
