Is battery life affected much by rooting? I'm not see any drastic reduction so far although I did drain it to about 18% with all the downloading I've been doing!
Shouldnt affect it
I agree, the rooting process itself should have no effect. The difference, if any, would be a matter of the CM7 ROM power usage vs. the stock ROM power usage. I recall something about sleep mode problems in CM7 making it a little worse, but that might have already been fixed. I'm pretty sure JP will be able to set me straight on that point.
I downloaded Nook Tweeks but it's useless. Says it's not compatible and "a newer version of Dalingrins kernal is required" I'm running CM7 (7.0.3) off an SD card.
U need newer CM7 version to use Nook Tweaks.I downloaded Nook Tweeks but it's useless. Says it's not compatible and "a newer version of Dalingrins kernal is required" I'm running CM7 (7.0.3) off an SD card.
