Battery only 1 hour to use
macaddict01
Hi, I have a Zenithink C91 ZT-280 and my battery only goes for 1 hour before it is empty. Recharging wil take at least 6 hours so the fun is a bit out of using this tablet. Is it possible to change the battery or is that too expensive?I like to hear from you.
leeshor
6,328
1,036
I would make certain you are using the charger it came with but it sounds like the battery may be failing. I can't think of any activity that would make it drain that quickly and it's way to long a charge time too.
