Hi, I buy a EPAD and download a firmware to update and finally came a warning that says file-system partition Erase fail! exit
Maybe the kernel don't support this nand flash.
The problem is that I dont made a backup program and now will start and makes the screen goes black I wanted to know if there is some kind of factory firmware to resolve this problem.
These are the details of EPAD.
Features:
model: generic
kernel version :2.6.29-00 236-dirty-g4f8dbbb
NWM build: WMT 2.1.2-105
1. ARM926 533MHz VIA WM8505.
2. WiFi 802.11 b / g, upgrade OS to Android 1.6 Android 2.1
3. 2GB DDR, 256 MB RAM
4. Touch screen 7.0-inch, 800 x 480px Resolution
5. Ebook reader, microSD slot
6. G-sensor, Loud Speaker, Google Browser
Platfrom ARM 9 CPU, VIA WM8505, 533MHz
Google Android Operating System 2.1 (upgraded from Android 1.6)
256M DDRII Memory
2GB Flash Storage Device HDD (standard, optional up to 32GB)
LCD Screen 7 "Touch screen, 800 * 480 pixels
LAN / 10/100 Ethernet Access WIFI 802.11b / g
Camera 1.3 mega pixel camera
Soft keyboard Keyboard
Full-size Operation Touch touch operation, sliding menus, icons
USB Port 2 x USB port (via the external usb pot)
Card Port SD CARD (512MB-8GB)
Effect Sound Build-in stereo speaker, microphone
MIC Jacks in & Headphone out
2400mAh Battery
Working 3hours time (standby time 7 hours)
Accessory AC adapter, user's manual, extrenal RJ45/USBpot, packing box
Fring software, QQ, MSN, Youtube, Google Map, Document To Go, Multimedia Player, Email, File Explore It, Application Store
size size: 22.9x15.6x6.8cm
weight 1.0kg
I await your prompt reply thanks
Features:
model: generic
256M DDRII Memory
2400mAh Battery
weight 1.0kg
