Help with ICS firmware for 9.7inch allwinner tablet
clmcc007
Mid Android 9.7inch Tablet PC running 4.0.3
Specification:
Screen Size: 9.7 inch screen, 4:3, Resolution: 1024*768
Operating System: Android 4.0.3 ICS
Touch Screen: Capacitive 5-Points Multi-Touch Screen
CPU: Chipset: Allwinner ARM Cortex A10, Cortex-A8, 1.2 GHz
RAM: DDR2 1GB
Storage: 8GB
Flash: Support Adobe Flash 11
WiFi: Built-in Wifi IEEE 802.11b/g/n 11Mbps to 54Mbps
External 3G is supported, WCDMA/ TD-SCDMA/ CDMA2000/EVDO.
Camera: Front Camera: 1.3 MP. Back Camera: 2.0 MP
Hi everyone,
newly here. Looking for help with my tablet. I am led to believe that I need to re-flash my firmware, to get it to work again.
I have tried to press reset button, but nothing. have tried the hold volume key and power key exercise and nothing. Just blank screen. Live suit does not see the system. At the moment it makes a nice paper weight. Any help would be fantastic especially if it gets it going.
AdamMuhammad
I think thats macsonic :p. Just search for 9.7 a10 firmware and get any of it. At least they have same size, resolution and chip.
