How to Create Full ROM Backup? And a Few Other Questions...
Folken
17
Here is the info from /proc/mtd . If you can tell me which mtdX relates to boot.img, bootloader.img, and recovery.img . I can try to get a dump script working. Thanks again.
uid=2000 gid=2000 groups=1003,1004,1007,1009,1011,1015,3001,3002,3003,3006@android:/ $ cat /proc/mtd
cat /proc/mtd
dev: size erasesize name
mtd0: 00a00000 00100000 "SysInfo"
mtd1: 00b00000 00100000 "Uboot"
mtd2: 07600000 00100000 "kernel"
mtd3: 02c00000 00100000 "RKer"
mtd4: 18000000 00100000 "System"
mtd5: 68000000 00100000 "Data"
mtd6: 20000000 00100000 "Cache"
mtd7: 54800000 00100000 "user"
vampirefo.
Developer
Nov 8, 2011
3,836
1,394
mtd2: 07600000 00100000 "kernel" boot.img
mtd1: 00b00000 00100000 "Uboot" bootloader.img
mtd3: 02c00000 00100000 "RKer" recovery.img
mtd4: 18000000 00100000 "System" system.img
crnrstne
7
traveler1701 could you please send me these files that you refer to so i could install the gapps on my 9742? i would greatly appreciate it. thanks
Traveller
2,859
984
The Development Index sticky has the root tool along with links to the CWM images. The modified framework-res.apk and the tweaks are in my signature. I will be updating the tweaks soon, as my build.prop in that file doesn't work properly and there are some additional XML files missing. For replacements I am using the files from Mobiz V.2.
Traveller
2,859
984
Yep. There is a link in the Development Index sticky that should be helpful.
zekeS
12
yah but wouldnt the tablet need cwm installed what i need is a way to recover from the recovery menu
Traveller
2,859
984
If you ask Vampirefo, depending on his schedule he may be able to cook up a solution for you using the dump and the stock recovery.
