Hallo, just installed nfs most wanted on my tf700 after downloading it with my pc.
Installed correctly and runs but oh so slow. Is way too easy to play like this
Anyone any idea how to solve this?
So much of the performance of that depends on other things going on it's hard to tell. The first thing you should try is a hard reset, (cold boot). Then I would look at any active wallpaper or active widgets actually doing some real background tasks. You also might look at any AV software you may be running.
hello, it doesn't seem t be lack of calculting power but more like a setting or incompatibilty issue? could that be the problem since EA didn't give it free for the transformer yet?
