AndroidApple
- Nov 22, 2010
- 10
- 0
Anyone have a Gpad G10, specificially from Pandawill?
I've had mine for about a week, and I noticed that it seems to only charge to 90%. I've never seen my battery say 100% even after an 8 hour charge. And once I unplug it and turn on wifi it can quickly jump down to 70% and after mild usuage only gets worse. I probably can get about 4-5 hours on a full charge, which I guess isn't bad, but it bothers me that it's not getting the full charge.
Anyone else have this problem?
I feel as though the charger that is included with the Gpad is complete crap. Since the usb cord they sent me was also crap. I ordered a charger on ebay for the Kindle Generation 1. It uses the exact same charge 5V 2000mA, and the same pin size.
Only thing is, can these devices be charged with a 9V charger? I know there are several different versions of this tablet, different batches, etc. Some came with a 9V and some came with 5V.
So do you maybe think that this things not getting a good full charge because its' the wrong charger for the device? Also maybe if it was the wrong charger, it could mean that the battery wont last as long once it's "fully charged"...
A seperate problem I am noticing is all the useless crap that this firmware has on it. Since the firmware is ripped from a phone, it has phone apks, telephony apks, mms apks, etc, some of which are constantly running and seem to be drawing life from the battery. In "Battery Use" under "About Device" in settings, I discovered that "Cell Standby" was using 75% of my battery! I installed an airplane mode widget that allows me to use Wifi while airplane mode is on. Since then the "Cell Standby" battery percentage has dropped from 75% to 14%, which to me means that the cell radio is drawing less battery, which is good, however I am not sure if it has had any benefits for increased battery life.
I'm still learning the whole Android OS. But I wonder if any of you guys have information on any of the stuff I have mentioned.
I hope a custom firmware will be released soon that doesn't have all the unnecessary apks that this firmware seems to have. BTW, I have firmware #370. Thank you in advance to anyone that can help me, or give me ANY sort of information.
Other than this, I am generally satisfied with the G10, if the battery charged to 100% and stayed full longer, I'd be so happy. Market works, speakers work, touch screen is quite responsive for a resistive type screen, I'm hoping in the future we can modify these things to run a lot better.
