Problems With Tablet 7 (ZTE Q7S) RockCHIP3188
aloivera74
Apr 4, 2020
I write through a Google translator
HOPE YOU UNDERSTAND ME
i have a tablet
(ZTE Q 7S)
CPU ROCKCHIP 3188
rk 30SDK
8 gigabyte
1024 \ 768 resolution 7 inches
1 gig of memory
I wanted to update it to version 5 with a different firmware ..
I flashed + I flashed the kernel to version 5 .. now I can’t flash more than one firmware of 4 versions of other devices ...
The flasher sees the tablet
played and dump did not
(I know that you will answer about this ... thank you I confess)
dug up the entire Internet I can not find the firmware on it
please help make a rollback ...
give someone a firmware dump + kernel
There are definitely a bunch of similar tablets ... how to rollback
bring back version 4
There is power but the tablet does not turn on ...
I found here such a folder with firmware no I don’t understand how it
there is a flash through a mini SD card
then I have a broken connector it is not
From the recovery there was a black screen initially ...
(I emphasize that all drivers are installed ...
there is a special button on the switch board
which puts it in firmware mode without battery)
I hope you understand that Google translator translated
aloivera74
Apr 4, 2020
Here is a photo of the firmware that I found for my tablet
only I do not know how to flash it
Tell me how to drop everything into one file. Img
how to roll back
I need another karnel dump
Traveller
2,858
983
Without a link to the actual firmware most of what I'm going to say is speculation. That said, from appearances you need Google's ADB software, Google's ADB drivers, the drivers for your tablet, and software - for example, MiFlash - to flash the files you have.
Russian Translation (Courtesy of Google Translate): Без ссылки на актуальную прошивку большинство из того, что я собираюсь сказать, является спекуляцией. Тем не менее, по всей видимости, вам нужно программное обеспечение Google ADB, драйверы Google ADB, драйверы для вашего планшета и программное обеспечение - например, MiFlash - для прошивки имеющихся у вас файлов.
aloivera74
Apr 4, 2020
not suitable
this is for xiomi firmware
aloivera74
Apr 4, 2020
ahh understand ..
me like that
Flash_tool_1.7
RKAndroidTool
rockchip-batch-tool-1.8
Suitable .. on firmware 1 file ....
I will wait, maybe someone will find
I have been looking at many sites for 3 days
I never found ...
