Requesting Firmware Dumps from Coby Generation 3 Devices
Status
Not open for further replies.
acidburn23
135
Here's the dump from the 7048 7048_dump.zip. Used this method from vampirefo.
adb shell
su
mkdir /sdcard/dump
busybox tar -cvzf /sdcard/dump/7048_system.tar /system
cat /dev/mtd/mtd6 > /sdcard/dump/recovery.img
cat /dev/mtd/mtd0 > /sdcard/dump/boot.img
cat /dev/mtd/mtd2 > /sdcard/dump/system.img
the firmware is good? :D
acidburn23
135
adb shell
su
mkdir /sdcard/dump
Hey strat6 your firmware is working in smooth? to reflash my device to fix my 2nd internal memory & you know how to Reflash?
jayson3st
8
I was just wondering if there was a way to get back to the original Rom for the 9742-8 yet? I installed the livesuite Rom a few months back and it works decent but just want to get back to stock. Thanks
vampirefo.
Developer
Nov 8, 2011
3,836
1,394
just restore your backup.
acidburn23
135
I have a system dump too now i create system dump from my friend he uses a mid7048 too i want to upload the dump the problem is my internet connection is slow xD
acidburn23
135
question? i download the system dump of 7048 too from strat6 the file size is 300mb? boot(10,240kb),recovery(10,420kb),system(389,120kb) then 7048_system tar. (153,848kb) is this good? i will try to reflash my Mid7048?
Traveller
2,859
984
Read the Development Index and Root Utility sticky. I provide a link in the System Dumps post to a post by Vampirefo which explains how to restore the system dump without using Livesuite. Be aware however that even though you have a dump now, it may not successfully restore due to Livesuite tampering.
jayson3st
8
Sent from my GT-P6210 using Tapatalk 2
Sorry most of this is foreign to me lol. I don't think I made a backup and if I did im not sure how to do it :banghead:
I've been reading up on this forum trying to get familiar but its sinking in very slow lol.
vampirefo.
Developer
Nov 8, 2011
3,836
1,394
If you don't have a backup, then you have nothing to restore.
tpaine
525
130
There are at least 2 system dumps of 9742 in the requesting firmware dumps thread. The 9742 has at least 2 or 3 hardware versions so these may or may not work for you.
vernsturn
Tried uploading my zipped dump file, but says file is too large @ 133mb. Should the dump not be this big?
It's from a new 9742.
Status
