[ROM][7.1.2] Unlegacy Android 7.1.2 (Nougat)
OmegaZeroXIII
Apr 7, 2021
At the time of installing the ROM when I want to put the Gapps that are nano. It throws me an error 70 in the recovery saying that I do not have enough space in the system
Traveller
2,858
983
If you get error 70 with the nano package you have two alternatives. The first is to use the pico package. The second is to use a package of roughly the same vintage, like [GAPPS] [7.1.2] [ARM/ARM64] [July 25th] Beans GApps . The problem you're encountering is that the app sizes have increased in the intervening years between the release of this ROM and now, and unfortunately the system partition of the A2109 is too small for it.
Based on the link I provided, you'd want the mini package, as the apps in the full package - except the camera most likely - can all be downloaded direct from the Play Store.
OmegaZeroXIII
Apr 7, 2021
well I solved the issue of the Gapps ... but I have a question, is it normal that it suddenly restarts with some apps? install firefox as a browser and I had to remove it because the tablet restarted. In addition, I also downloaded the plants vs zombies 2 and when I start it I have a black screen, something that did not happen before with the previous rom that I had which I do not remember what it is because the tablet was brought to me after so much in very bad condition and this before I remember that I had a boot image of a record player that put the rom but I don't remember what it was called
Traveller
2,858
983
It's not normal. I assume you put the ROM on the device, but did you wipe data and cache? If you didn't properly wipe the tablet that could be the source of your problems, in which case you want to wipe the tablet and try again.
tarassaco
Feb 14, 2022
Hello,
I rustled up two Acer Iconia Tab A500 Android 4 still working (8GB the first and 16GB the second one)
Being a newbie I don't have a clear idea from where to start to update version 7.1.2
Traveller
2,858
983
Hello,
Hi, I have a Galapad 7 tegra 3. Which one would be compatible?
Many thanks!
These ROMs won't work on your tablets as they are specifically designed with the Lenovo A2109 in mind. Since the hardware drivers have to be compiled into the kernel installing this ROM on your tablets is likely to irrecoverably brick any tablet other than the A2109.
pst
Hi.
I recently was given a Medion Lifetab S9714 (= Lenovo Ideatab A2109). Installing TWRP was not too difficult.
The only newer ROM I could find was CM-12.1 for Lenovo a2109 (20160901).
Has anyone still access to
- ua_a2109-6.0.1-20170916175354.zip
or
- ua_a2109-7.1.2-20171102085214.zip
which I could not find anywhere?
Thank you!
pst
konogon
Hi.
or
Thank you!
pst
in my opinion, the best one is ua_a2109-6.0.1
