flashallthetime
- Dec 28, 2012
- 499
- 235
- Thread starter
- #61
Update to rom camera fix applied
Sent from my Evo 3D GSM using Tapatalk 2
Hello,
Could you give the CWM that you use as I want to make Nandroid backup then install the new rom.
I'm using A2109A_MCL0201 rom and with out external sd card.
Because the last time I've tried to restore my backup but the recovery (A2109_CWMrecovery-6.0.1.9d) wasn't able to restore the backup from internal memory.
also I've tried this one(A2109_CWMrecovery-6.0.2.8a) and it doesn't work also.
Thank you.
Yes I installed cm10.1(I think it's 4.2.2) after A2109A_MCL0201.Which one do you use -6.0.1.9d or -6.0.2.8a.
and now I flashed -6.0.1.9d, is backup and restore will work again?
Thank you
