Stylus Audio Visual WiFi ATAB0207
wintry8
It wont switch on. It went flat, i put it on charge, it showed the red battery image when it started charging and now nothing. It's been charging for 24 hours straight and i know the outlet is good and that the charger is working. What can I do?
My whole business life is on the tablet!
tragidy
Jan 29, 2011
826
433
Try charging it with the usb from the computer to tablet, let it sit for 1 hour, power it on and get your life off of there or inspire a contingency plan for future fail overs.
wintry8
And if that doesnt work?
KenB
There's a small hole on the side where the power connector and USB are. That's the RESET button. Use a paper clip or similar to press that.
I've had the same issue with the device hanging and not wanting to power up that the reset button sorted out.
