Weird Battery Problem With Coby Kyros MID 7032
Rave
I've been having this problem for 3 weeks now. I have a MID 7032-4 tablet and its not rooted.
Everything works fine except when I turn off the tablet. I do not put it on standby but I shut it down.
After 24-36 hours of being shut down, when I turn it on, I lose 50-60% of battery. (e.g. I turn it off at 90% I now see 30%)
I have optimized all my settings for battery performance (wifi turned off, airplane mode, display dimmed, battery saver app, everything.)
I have proven this because on standby / sleep I lose only 5% of battery life. So no problems when in use or in standby. Only when turned off do I lose a lot of battery.
I have done a factory reset to no avail. I tried a full charge and full discharge to no avail.
It also seems to happen once 24+ hours have gone by.
Because if I turn off my tablet for only 12-13 hours, I don't lose any battery. At most 2% which is normal.
Rowdyeh
145
24
Hi Rave. That is strange! If the tablet is shut down then it should lose hardly any power during that time besides the normal battery leakage which is tiny. Suggest you don't shut it down at all unless you absolutely need to, my tablet is always on standby when I'm not using it. You should contact the manufacturers about this problem? Good luck!
