wondermedia Wm8650 upgrade removing battery issue.
free2fle2010
hi,
i am new to this forum and really dont know much abt the i am search for update or change the existing android version.
as its chineese and chinese android market.
Model :- wondermedia Wm8650 tab with gsm calling.
android os 2.2
kernel :-2.6.32.9 default
build version v1.5.5
build number :- generic-eng2.2 froyo ver1.5.5-20111010.82117
i wanna update the device to android ics
Spider
15,781
1,812
Hi, congratulations on your new WM8650 and welcome to the forum. I'm moving your thread to the WonderMedia Based section for you, where more people with that tablet are likely to join the discussion and try to help you. Good luck!
cal67
178
15
ICS won't work on this tablet, the hardware can't handle it. I would suggest using Uberoid. Go to TechKnow and sign up. Get the proper changer.bat number based on the tablet size, resistive/capacative screen, charge and power LED colour, etc. Follow the instructions to install the files on a microSD card, and install to your tablet. It makes a huge difference.
