use trickbikers stock os backup doesn't sound like your bricked at all
http://www.androidtablets.net/forum...-anyone-have-stock-rom-7022-a.html#post133151
i have the same need for a 7012 - Stock Kyros 7012 OS Backup.zip ???
My system details:
Model number: MID7022
Android version: 2.3.3
Kernel version: 2.6.35.7
Build number: MID7022 20120106
I have a brand new Kyros, just out of the box today.
Unfortunately, I failed to make a backup of the restore partition.
I have tried numerous restore images and the tablet does not load the restore menu.
If you can get me the original / custom restore, I will be able to make a system partition backup.
I too need this stock ROM and MTD.img so I can flash from FDWN
My 7022 is stuck in a boot loop @ the initial boot image. Prior to that I had tried clockwork and lost the ability to launch recovery. I then tried the FDWN files for the cyanogen mod and the ones for the what is it EM73 Both of those write and checksum ok but do the looping
have you found any way to fix no touch screen and reboot after 30 sec . min is doing that right now
I believe the answer to no touch screen - at least for my tablet - is to restore the stock MTD and lk.rom files for the build date of 20120106. Still trying to find someone with the files. I did hear from someone on xda dev site that is expecting a new 7022 tablet in the next week or so and they plan on trying to revive theirs using ADB to pull copies of these two files from the new device then push them to the one the one they soft-bricked. That is assuming the build date is on or after 20120106. There are still plenty of 2011 tablets being sold. If they get the right dated files and it works, they said they would post copies of the files so we can get running again.
the touchscreen thing is usually fixed with another boot.img file - I have one but sadly it makes no difference because I dont have wifi or external sd support with the backup I have. Sucks. If it helps you, the cm7 has a proper working touchscreen driver in it, if you can extract it, please also extract the wifi driver and update it and then post it here![]()
You can try the stock 7022 I put together should at least get you back to stock 7022.
http://www.androidtablets.net/forum/coby-generation-2-technical/41455-help-recovery-7022-a.html
where is cwm7 for 7022 so I can pull the wifi from it?
also go a head boot into recovery and do a factory reset, then reboot and test wifi.
