- Feb 8, 2011
- 72
- 3
I am very happy with my Vega. Affordable, enough battery life time (I get 10h with normal use), and with a custom ROM fast enough. There were no Google apps in the original ROM, but there are solutions to get them. Either you do like macc2010 and ask the dealer to install it for you, or you follow the explanations in the MoDaCo forum to install them by yourself.
I suggest that you go for a custom ROM, it is not difficult to install but it makes the Vega faster and more usable. I changed from the original launcher app to Zeam, runs nice and smooth on the tablet.
The screens viewing angles are limited, but good enough for daily use. The USB can be used as a host (with the MoDaCo ROM) and you can even plug a 3G dongle and get internet access on the go.
You can check my short review on my homepage for more information.
