Allwinner A13 7 Inch Tablet Problems
Hi
I've a problem with my son tab...
Model = XENIX A13
Baseband version = 1.5
Kernel version = 3.0.8+
Build number = nuclear_pfdq88c-eng 4.0.4 IMM76D
Specs :-
Processor = Allwinner A13
GPU = Mali 400
Display = 7inch 5 Point capacitive Touch , 800 x 480 pix
Memory RAM = 512M DDR3
Storage = 4GB
Interface = 1 x USB Port(OTG Port / USB Port)
1 x 3.5mm Stereo headphone port
1 x Mic
1 x TF Card Slot
Wifi = Realtek 8188 WIFI LAN 802.11b/g/n, 150Mbps
Camera = Cmos Front 1.3 Mpixel
http://www.comfortsu..._A13s/pink1.jpg (Mine is RED)
He forgot the pwd at screen lock after entered a password (combination char & num)...
I've searched a solutions to remove the pwd but failed. Managed to find remove pattern lock only...
Furthermore the tab haven't be set to "Debugging" - ADB Mode resulting I can't get ADB shell cmd to execute any cmd...
I've downloaded the nuclear stock ROM and patch it via LiveSuit1.09 and succeed...
However when booted, the screen hang at Android light green screen...
The Android light green display fits screen nicely... There's no 1 inch shift to left or right like reported by other users...
May I know how I can enter to recovery mode from here so at least I can clear/wipe dalvik/partition cache and perform a factory reset...
Or how to solve stuck at Android light green screen...
Many thanks...
