Hi, I've been having problems on my tablet that the battery appears not to charge and have discovered with a higher voltage input (7.5 - 9volts) the tablet goes. Can anyone tell me what battery voltage should be and what the output voltage of the charger should be? The one that came with it is 5V. Mine is the 10 inch Magnitab and I wondered if a charger for the 7 inch version has made it's way into the box at the factory.
Cheers
Brian
Cheers
Brian
