Battery Replacement In Progress!
I have a 7015 and after only a month of use the wire on the charger split from the base. I cut it off since it was just hanging by a thread, and then accidentally lined up the wrong ends and heard a pop in the tablet. The tablet didn't shut down but the battery won't charge now, I tried charging it with a new one from radioshack. I assume the battery is blown out. How difficult is it to change?
That's not the battery. You blow something else.
