leeb
- Jul 16, 2011
- 463
- 21
I would like to suggest that you attempt a
fsck /dev/block/nande
on the faulty tablet, and see if it is able to clean it up...
if not, attempt to copy the /dev/block/nandg (recovery partition device) from the good tablet to an external TF card file as I posted before, and then attempt to copy it to the same nandg device on the faulty one. This OUGHT to get you a working recovery on the faulty one which should fix the factory reset issue... at the least you may be able to clean/fix the /data partition that way.
AND/OR
you could also do the same with the /dev/block/nande (/data) partition and possibly get a clean(er) partition that then could be more easily repaired.
Just some thoughts!
AND/OR
Just some thoughts!
