Bricked Nook with no way to fix?
You need to go here: and follow these instructions: http://www.androidtablets.net/forum...e-bootable-clockwork-sd-card-0-1-cm7-rom.html
This is to create a ext4 Bootable SD to install CM7. Try this just to see if your NC will recognize and boot from it.
ok. im prepared to try this and see if it'll work...but for once, im actually checking the md5 sums and after about 20 download attempts, i get the wrong md5 sum every time...so before i go ahead and do more stuff...what's going on? thanks a lot in advance
You're getting a bad download. Try one of the mirrors and if you are using a torrent link, try a different one. Which file are you trying to get?
im trying for the 8gb_clockwork-0.1-ext4.img file. ive also tried for the 1gb. ive tried all the mirrors already and i get the same md5 sum each time. i have no idea why
Try the 4gb image, I have read that some folks have trouble when the img file is the same size as their card. I didn't have any problems, but I only had a 4gb card to use. Here's a direct link to my copy: 4gb_bootable_CWR-ext4
MD5 for that one is: 71ba12fc908c6bcc643aec6e9359b9f1
i also got an incorrect md5 sum from that one which im starting to think is my problem.........
i got it to boot into CWR and im gonna flash the 1.1.1 stock rom
If you are using cwr 3.0.0.6 that is ext 4. You can't use that to flash stock rom. I can't give the link now but you need to tale extra steps when on ext 4 search before trying to flash 1.1
First off, congrats on getting it to boot. That solves the first question of just how broken your nook is. It means that its not so broken we can't fix it.
However, WHAT HE SAID, with my ext4 SD card image, you can not flash the 1.0.1 recovery. You can only flash a CM7 or phiremod v3 rom right now. You SHOULD however, be able to add the restore_boot_partition.zip file and flash that which I think will fix your primary issue. Fix that boot partition, remove the sd, and you should be able to get an 8 times restore process going.
I did exactly this, and it worked! After I got CWR working, i used the boot partition fixer and installed a clean 1.0.1. That got stuck at the grey, "n" screen, so i did an 8 times factory reset and its back clean and autonooted again and for now, im gonna keep it that way. So incredibly greatful for all the help i got today. You guys are great, and saved me a whole lot of money and trouble.
Awesome! Welcome back to normal. :)
By any chance do you have ATT dsl, one of my friends cannot get a large download or upload to work?
