MikeViller
- Nov 25, 2011
- 54
- 5
Anyone have sound problem, on certain player (moby) and the web I can barely ear the sound. Just to let know !!!
@Steev, hey pal do i need script manager to load the kickass kernel and the v6 supercharger @ boot? im not planning on modifying the settings so if its not needed i would like to uninstall it.
Sent from my Coby Kyros 7024 Gingerbread by Steev
Installation instructions:
- Download the file above and rename it to "upgrade.img"
- Copy "upgrade.img" to your sdcard (internal or external)
- Boot your tablet while holding the HOME button
- You should see a message like "utscript1.sh file found. press volume up key to upgrade".
- Press the Volume Up button to install the boot animation
Wait .... dies this mean it may now be possible to run updates instead of complete new flashes? IE theming type updates and such?
Is it documented somewhere? Thanks a lot!![]()
############# for recovery #############
mkdir /mnt/tmp
mount $UT_MMC_DEV /mnt/tmp
if [ -e /mnt/tmp/upgrade.img ]
then
mount /mnt/tmp/upgrade.img /mnt/mmc/ -t vfat -o loop
cd /mnt/mmc/
urbetter_upgrade &
dd if=/dev/zero of=upgrade.img bs=1M count=0 seek=<size>
/sbin/mkdosfs upgrade.img
mcopy -i upgrade.img <files to copy> ::.
steev's V1.0? Nope, only using another Launcher AFAIK.
