CFW for MID7024 based on Alldro2 Gingerbread
Yeah honestly i dont know how much time i would have hold on with the OFW. xD Ahmm detail is, its difficult to send a cake to other country xD
What is that shortcut on the main page (v1 ROM); one with a rectangle or something. Its saying, "Problem loadin" for me.
Thanks..
Thanks..
I think it's supposed to be ES Task Manager, but I didn't include that app.
You mean on a workplace, where icons go besides the app drawer? Probably a widget, you can remove it by tapping&holding and then moving to the trash can on screen.
Hi Steev,
Just wanted to thank you for this amazing ROM. Fixed my battery drain issues majorly and I now am experiencing battery life of up to 3-days on a single charge. I was wondering if there was any thought regarding the screen rotation animation framework in to an upcoming iteration of the ROM. Some folks seem to have gotten it to work on the Samsung Galaxy SII: http://ykkfive.blogspot.com/2011/12/sgs2-screen-rotation-animation.html
I
will try to use this method a little later on today to verify if it indeed works. It would add a really great touch to what is already an absolutely AMAZING ROM!
Thanks again so much!
Yea i was able to remove without any issues. Thanks..
Sent from my MID7024 using Android Tablet Forum
Hello.. I bought a 7024 for a x-mas gift and using this ROM, fell in love with the tablet and ended up getting another one for myself. But, I noticed that with the old tablet, I had updated to the 0.3 ROM instead of the 1.0 ROM. With this new tablet, I installed the 1.0 ROM.
But, I'm having calibrate and workspace swipe issues and some programs which I had previously installed and they worked fine on the 0.3 ROM, don't any longer; appears as though I get more crashes. Sometimes too, the tablet will just stop responding for a few seconds before responding.. Anyone else having odd issues as well?
Namely with the calibrate, if I calibrate in landscape mode and then switch to horizontal mode, the keyboard doesn't hit the key properly. Same if I calibrate one way and switch to the other. Thanks.. I love the ROM and if anything, will switch back to the 0.3 instead of 1.0..
I
Didn't work here... It seems that it requires other libraries as well that doesn't run on Kyros unfortunately...
kk, someone else is having issues with the music app? just starting it, and playing song, gets crashed. every time. tried to clear data and stuff. nothing. gonna reinstall it to see if it solves issues.
Sorry guys I've been slackin'.
I'll see if I can reproduce these issues reported.
Something odd this morning, upon power up, date and time were off. Date was 1/1/2010 and time was 4:30pm. Powered off normally and had it plugged in all night.
Not sure what happened.
Sent from my Steev Rom v1.0 MID7024
How do I stop Market from being updated automatically? I'm using the version 1.0 ROM which comes with Market 3.1.3. It's auto-updating it to 3.4.4 and once this is done, I constantly get force closes while doing searches. If I uninstall the 3.4.4 update and go back in, Market closes and its autoupdated again. UGH, annoying.
Thanks..
I can do a search, but when I click on an app to install, I get a force close saying "Sorry!The Application Market (process com.android.vending) has stopped unexpectedly. Please try again".
Thanks..
I think i have it working and not updating to 3.4.4. Anyone else having issues with 3.4.4?
Sent from my Steev ROM v1.0 MID7024
Recovery from tablet touche screen
TeamWin Projects - TWRP 2.0
Have you tested it? No Kyros model is listed as compaitble...
Thanks..
I think you need FOTAKill.apk if you are using any 3.x version (2.x versions need MarketUpdater.apk to update themselves). But it's weird since my version is still 3.3.11, and it works fine (different hardware, but steev's CFW is similar to mine).
