cornell
- Jun 13, 2011
- 75
- 5
Sorry if I'm slow to release updates to this ROM.
My work on Honeycomb begins now![]()
Hail to the king baby!!! You're awesome dude, big thanks.
Sent from my Coby Kyros 7024 Gingerbread by Steev
LONG LIVE THE COBYSCRIPT-LORD! hahaha hope we can see that work finished ver, very soon mateif i get the permisions would you use a new boot animation? its a cool one, i asure ya, its already in my iconia, but i wanna see it in my kyros
EDIT: K, its HARDER to turn off than turning on my tablet. hooooly crap. Does anyone know a way to turn it off with a apk, script or something? thnx![]()
i am very sure, if you download it from the 'herotab' site forum, it has the internals set to "that" specific hardware. so do not install ! ! ! . @steev ( or one of the other 'heavy lifting' devs ) in this forum will have to make changes for it to be okay on the coby . . .steev i just saw the honeycomb topic on slatedroid, so you think this time we gonna have 3.0 ou our coby's?
i am downloading the alpha from the topic, alpha 2. It will install on my 7024?
No, you must install 1.1 first, then install the SP1For SP-1 for 1.1, can we just copy over the SP-1 upgrade.img file and replace the one which comes with the 1.1 ROM update files? I plan on doing a fresh-update anyway. Thanks..
su
reboot
dude can you share that boot animation?
regarding the turning off app, i think there are some apps on the market that let you do that, for example i remember i downloaded months ago an application for rebooting the system and it has the shutdown option too i just can't remember the name of it.
EDIT: Successfully installed the SteevMOD SP1. working very good, as always xD
So the steps would be, newly formatted SD card copy over 1.1, do the ROM update, reboot, shutdown, reformat SD card, copy over SP-1 then do the update once again?
