Kiserian
- Aug 28, 2011
- 51
- 4
@Josfer, as said in the first post, use the rom at your own risk. If you follow the steps the tablet wont brick, at least not under normal conditions. Even so, you've been warned! xD
About the reboot issue, the battery indicator doesnt say anything? its a hard reboot (just powers off no matter what you're doing)? post as many details as you can, but may be you should post in the technical section.
Good luck pal
Good luck pal
