Hi folks.
I've installed 4 or 5 different ROMs thus far on my nook, and each time I used a bootable SD card which runs ClockWorkMod. I then install a ROM zip that I had copied to the card from my PC.
I only own one SD card, and since it's bootable, I don't believe I can use it for external storage (somebody correct me if I'm wrong).
I'm running phiremod 5.2, and noticed that CWM is an app in the ROM. Theoretically, you can install a new ROM while running your current ROM. However, this assumes that the SD card is mountable/accessible, and given that mine is bootable, I don't thinnk it is.
I'd love to use my single SD card for both external storage and for installing ROMs. Can I do this if I run CWM from within phiremod? I don't know if it makes any difference, but the CWM on my SD card is 3.0.1.0 and the CWM on phiremod is 3.0.0.7.
Thanks!
Thanks!
