emmerick
- Mar 14, 2011
- 80
- 2
Yes, I'm pretty sure the problem described is due to a Windows limitation. Not COMPLETELY sure because I didn't even give a try in WindowsI use Ubuntu and gParted for almost all my partitioning needs.
I also have that issue. Since then I can't mount the sdcard to the pc through the tablet. Have to take out the sdcard and use a card reader. I'm not sure how this can be solved but I'll do some research.
Also, about the other issue, I'm not sure about USB flash drives (will give it a try later) but I can use my mini USB keyboard with no problems.
As mentioned before you probably can't "see" your sdcard in your PC anymore when connected through USB. Use a card reader in the meantime. I'm not sure about Windows but in Linux you should see the two partitions of your sdcard when you insert it in the card reader. Just copy their contents and repeat the partitioning process with your new card, then copy your files to their respective partitions as they were before. Don't worry about the size of partitions. Link2sd should recognize them with no problems.
Hello friend thanks for the quick response, I think the linux should work that way but just add that also take a look at the root folder data/sdext2 to see if everything is ok because that way when I had some duplicate folders within this named of data/sdext2.
