- Jan 2, 2011
- 476
- 21
the unit will not connect to a WPA2/PSK...
if its WEP, it will connect
That's incorrect. My router security is WPA2/PSK and my Kyros connects just fine.
Also was wondering if there is anyway possible to put clockworkmod onto this tablet.
If your wifi was not working out of the box, and your router works fine, you probably have a defected tablet. Send it back to coby and have them fix it. If u have just opened it, your warranty should still be good. Just tell them what happened and they should repair it.Sup guys, recently purchased this Coby Kyros 7015 4gb model and right out of the case after setup Wifi would not connect. I've tried factory reset but that does not work either. I was wondering if there is anyway for me to replace the wifi apk within the system and start over?
