Craig CMP738B Rooted problem
sum_d00d
http://www.androidtablets.net/forum/craig-tablets/28344-craig-cmp738b-root-working-android-market-clean-rom-img-file.html#post159336
snip
I have had only one issue with this rom. In Security Guard when I try to run a malware scan or try to prevent apps from auto-staring I get the error "The application security guard (pocess com.rockchip) has stopped unexpectedly". Should I try to reset the tablet back to the factory rom and then reinstall? Or can I just try to reinstall your rom?
I would greatly appreciate your advice.
Can someone please give me some advice?
I am fully prepared to reinstall this puppy.
I just need a suggested course of action.
Do I?:
a. Restore to default THEN install the rom again? or...
b. Reinstall the rom without any other prep?
Please help.
