right i have tryed the reset button tryed the boot key config back + home + power when i connect it to my computer the makes a connected noise i was just wondering if anybody had any ideas if there is a way to boot via sd to recover or to flash by pc
Synrgic advise to carry out a factory reset from the Android Recovery Menu prior to flashing new firmware.
I believe the update must be carried out with the firmware files on the Dreambook internal memory ONLY - not from an SD Card. (need to confirm this)
To update the Dreambook W7 1) Power off the tablet 2) Remove 3G Sim and SD Card 3) Extract the two files: udpate.zip and bootimg.tgz from the firmware file and transfer to the Dreambook (Internal Memory) root directory 4) Press and hold: return + home + power buttons together to boot into the android system recovery menu 5) Select option 2 (apply sdcard:update.zip) and press the home button 6) Select option 5 (apply sdcard:boot.img) and press the home button 7) Select option 1 (reboot system now) and press the home button to power off the tablet 8) Turn the tablet on and go to settings 9) Select "About Device" and go to "Build number" - Check to make sure the dreambook firmware has been updated by viewing the build number.It is advised to select: wipe data/factory reset from recovery menu before carrying out a firmware update.PLEASE NOTE: FIRMWARE WITH HD104 or HD105 IS SPECIFIC TO DREAMBOOK HARDWARE TYPETo check your device: goto settings / about deviceThis will display the Version # followed by (HD104) or (HD105) this is your dreambook hardware type- As it has been asked a few times I thought it would be easier to find this info in a thread of its own. Hope this helps.
Yeah, it worked. I googled how to reset an android tablet and found out that there should be a small button that you should push using a pin to reset it. I did not find a small button on W7, so i tried to press anything that i can see, and when i pressed the charge light indicator, it worked.
damn it was scary =)
sharpness71 said:Just brought the Synrgic W7 tablet, and I'm having problems with it already. I have a 3g sim card that I can not get to work with the tablet. It can not find the network.
I input the settings from the provider, and still no service. They did not have the exact model of that tablet. So I looked through the list of phones to see the most similar. They had settings for Android 1.6 and higher. So, I input them.
I want to upgrade the firmware to Android 2.3, but I'm having problem getting my pc to recognize my tablet when I connect it with the USB cable, and I can not find the Android 2.3 upgrade anywhere. All the links are closed.
I'm new messing with Tablets. Any help would be appreciated.
HD105
Will be great! I find only mfgtools with 2.3 files, and no firmware files for flashing from recovery. Can you upload firmware or give any advice how flash worked dreambook with mfgtools?if someone want i will put an link to 2.3 firmware of course if I not get baned to put link. But if you read Dreambook thread no one not advice to use 2.3 because is very bugy.
Ilrilan said:Will be great! I find only mfgtools with 2.3 files, and no firmware files for flashing from recovery. Can you upload firmware or give any advice how flash worked dreambook with mfgtools?
If there is any problems with putting links, send please with PM
