A couple weeks ago I bought a Nook Color on ebay. The first thing I did was turn it on and let it fully charge overnight. I noticed that it was in normal condition, but didn't bother going past the intro screen since an off the shelf Nook Color was not what I was interested in anyway.
The next day I flashed phiremod 6.2 on it with no problems (I have done this process successfully to two other Nook Color's by the way). I am able to connect to my wifi, setup my google account, and open the market. Life is good so far. Then I notice in ROM Manager that there is a phiremod 6.3 version out. I try to download phiremod 6.3 from ROM Manager for an entire day with no luck. The download just kept stalling on me. No problem I'll just download phiremod 6.3 onto my sdcard and flash it through clockwork recovery as normal (performing a full wipe first of course).
Then boot loop for no reason I can tell. Just a boot loop at "Touch the future of reading" with no way to get into recovery without restarting it with the sdcard.
So I put the sdcard back in and wipe and reflash phiremod 6.3 with the same results. Then I wipe and reflash phiremod 6.2...boot loop again. I repeat this process until my eyes start to bleed.
At this point I'm thinking, "There's no reason this should be happening. I wish I could just go back in time and start over." That's when I find this link: [RECOVERY][ZIP] Nook Color Restore to stock - xda-developers
Ok, I'll just restore everything back to stock. No clockwork, no phiremod, just Barnes and Noble software just like the day it was born. So I go down the road of restoring the device to stock and instead of bootlooping at "Touch the future of Reading" it bootloops at the "N" screen. I'm running out of ideas so I perform the 8x method, get the OTA install, and still bootlooping at the "N" screen. Oh yeah, and "power + n" wont take it into recovery of any kind.
Now that it seems that I've failed to restore the device to stock, I try to flash phiremod 6.3 again because this is really my end goal anyway. This time it is a success. I connect to my wifi. The device says I am connected and the wifi signal is strong, but I can't establish a reliable data connection with google, or open the market, or browse the web. I turn the wifi off and on, I tell it to forget my connection and add it again, but nothing seems to work until a day later when it suddenly establishes a connection.
So everything seemed like it might be ok at this point except strange things started happening with the device. Power + n doesn't take it into recovery, and never did at any time it has been in my possession. When I try to go into recovery from ROM Manager after flashing CWR I go into a bootloop. This is even after updating Rom Manager and doing things like rebooting after flashing CWR. Wifi always says it's strong and connected but any app with internet access is often times painfully slow to the point of being unusable or at least impractical. Downloading a single app from the market is like pulling teeth, and I regularly get the "retry or cancel" popup over and over again. Sometimes when I tell it to reboot or shut off, I get the "rebooting" or "shutting off" message and it just grinds away endlessly.
The device is currently in a bootloop after just telling it to reboot (normal reboot not reboot into recovery), and I know how to pop in my sdcard with CWR and get out of it. However, my problem is that this is a gift for my sister, and I just cant seem to get this device into a normal working state that I can give to her.
I know that there are plenty of threads answering all of the little problems I have outlined here, but none have resolved them for me nor have I found a single thread that deals with a whole host of problems like this device seems to have.
Thank you for your patience in reading this.
