Hi ALL,
I have a 16 GB ext SD card with a bunch of videos. My next project is to try to get some full movies on it for use when I travel. On my PC I have one or two of those "digital copies" that you get along with a Blu Ray disc. I figured they were encrypted as they need some kind of license to play but just to see I copied it over to the Ext SD card and tried to play it and it was unplayable. Then I went to delete it and it no longer shows up but the reported capacity of the ext SD is not back to where it was before. Before the copy there was about 9 GB free out of 15 GB. The file was about 2 GB and now even though its been deleted its showing only 7 GB free. I used HD File Mgr to delete it and I know some people have been having problems with that. Is there any way I can get the free space back to what it should be?
Also, I hooked up the A500 to my PC and while I can see the ext SD it only shows up some folders but not all of them. Specifically the Videos folder does not show up. Not sure if this is related or not.
Any help will be appreicated!
Gerry
Gerry
