cfrockit
- Dec 26, 2010
- 627
- 191
- Thread starter
- #16
I can't get the burn tool to SEE the SD card... the dropdown list is empty....
The card must be clear of all existing Partitions.
The old partition needs to be deleted.
Using XP, click Start > right click My Computer > left click Manage
Under Storage click on Disk Management
In the displayed window, Click on the SD card first partition (down in the bottom right section of the window) and you should get an X on the tool bar (Under the word Help on the menu bar) which is Delete. Delete the partition so the card is blank, also no need to format either. Try again.
If you are unable to delete the Partition on the microSD card, search the Web there are many instructions describing tools/utilities on how to modify/delete/create partitions on Removable Media (USB, SD, external Hard Drives).
Thanks for the assistance, this will all go in the post for the rest of the EX users if you get this to work. If you do, can you also try the three finger reset to see if that gets fixed as well.
