FIRMWARE RELEASES: firmware files, benefits and bugs for the Flytouch2 v2 /Superpad 2
hi i bought an superpadIII (strange clone) armv6,api8,device androidtab 10(they changed build.prop),device mercury ,build FRF85B, hw imapx200 ,screen x600,kernel 2.6.32.9 root@jackie-desktop#79 what can i do???? try a firmware?
thx in advance
Do any of these ROM versions support loop devices? I would dearly like to run Linux CHROOTed under Android as described in How to Install Ubuntu on Android!
After some difficulty, I have successfully rooted my SuperPad 3 and installed Busybox, but have not been able to get Ubuntu to run. Any ideas?
Chris
Superpad 3 Android v2.3 2011-09-01 Kernel 2.6.32.9 Build FRF85B
HiyallI had the misfortune of buying a Superpad 9V,Blue LED (purple when charging),SAWEE10,Single SD slot,double USB port;Android 2.3(Fake?)3G does not work,neither does GPS, YouTube etc etc - but no-one can CONCLUSIVELY say if ANY of the Tim ROMs work with this unit.Is there a Yes/No answer? - I'm too chicken to experiment for fear of bricking and I hear this one's a B*tch to fix and read a ton on other Forumsbut no-one seems to know if these problems can be fixed.Anybody????:confused:
This post is intended to keep track of firmware releases, known issues and known fixes. Please post comment on any additional firmware that you have tested for this device that is not listed, also any bugs or fixes that have been missed. NOTE: These links are not provided by me, but have been tested by me.20110302 (Supposed Offical Manufacturer Firmware update #3)Link: Deposit FilesMirror: http://rapidshare.com/files/453540625/Superpad2-FlyTouch3-Firmware-Update-3-Flash.zipTested by: ChandosFixes:- Adobe flash player 10.1 installed.- See this thread for more info on Flash: SuperPAD II Adobe Flash Support Questions - Smoother user experience- Market does not show all appsIssues:- Angry birds and some apps wont install. Remove sdcard to resolve.- Screen is still dimmer- Audio speaker output is low- Flash is black and white and choppy- Causes issues with pads with new screen 1024x576 resolution.20110316 (Release #2 with Brighter Screen. origin Unknown)Link: Disco_10inch_android2.2_20110316_Bright screen.rar - 4shared.com - online file sharing and storage - downloadTested by: ChandosFixes:- Angry birds and some apps wont install. Remove sdcard to resolve.- Smoother user experience- Screen is brighterIssues:- Market does not show all apps- Flash is black and white and choppy- Audio speaker output is low- Causes issues with pads with new screen 1024x576 resolution.20110328 (Supposed PRERELEASE BETA Official Manufacturer Firmware update v4.9)NOTE: This is not an official firmware release, but a beta release of the upcoming #4 official release.Link: Deposit FilesTested by: GundamboyxFixes:- UnknownIssues:- Audio speaker output is low- Firmware version shows as 20110316- Flash is black and white and choppy- Causes issues with pads with new screen 1024x576 resolution.20110410b (CUSTOM ROM: Tim: Release 2b. Based off the 20110405 TCH ROM and 0302 and Dutch v4 Official ROM)Link: http://public.timduru.org/Android/Flytouch3/20110410/20110410_Tim2b.zipTested by: Maildrop, ChandosFixes:- Screen is brighter- Fix for the wrong colors in browser & apps- Increased sound volume from speakers- Ad-hoc wifi networks- Market 2.2.11 - Showing many more apps than previously.- Youtube 1.6.21 working great, fullscreen HD - Woking GPS with google maps & co (Chandos: Used GPS+CoPilot to drive to work, worked perfectly)- Updated framework & libs- Dalvik cacheIssues: - Some apps fail to install unless you remove the sdcard.- Calendar Sync gone.- Color issues persist in Opera Mobile- Flash is black and white and choppy- Causes issues with pads with new screen 1024x576 resolution.20110419 (CUSTOM ROM: thechillhacker (TCH) , Based Off his 0413 ROM)Link: http://thechillhacker.com/media/19Apr2011.zipTested by: ChandosFixes: (Same as TCH 0413 ROM plus)- More speed increases from VM heap size optimization- SD card access tweaks- Some library updates- Compiled a new busybox static binary (1.18.4) with all the trimmings, That should help with the Titanium errors and other things.- Compiled a new WPA_Supplicant (from AOSP git repo) to allow for all WPA variants while keeping ad-hoc support. Compiles and runs fine but still does not scan networks properly - I'll come back to this.- Compiled an entire AOSP kernel source tree (for the modules).- Touch screen calibration comes up on first boot nowIssues:- Some apps fail to install unless you remove the sdcard.- Titanium Backup crashes when You try and restore some apps (Generally the ones that require sdcard removal)- Flash is black and white and choppy- Causes issues with pads with new screen 1024x576 resolution.20110430 (Supposed Offical Manufacturer Firmware update #5 for 1024x576 pads)NOTE: ONLY use this firmware on 1024x576 resolution pads.Link: Deposit FilesTested by: UntestedFixes:- Screen resolution issues for new screen 1024x567 resolution.Issues:- Flash is black and white and choppy20110521 (CUSTOM ROM: Tim: Release 4e. Based off the 20110503 firmware)Link: http://public.timduru.org/Android/Flytouch3/Tim-V4/20110601_Tim4e.zipTested by: ChandosFixes: http://public.timduru.org/Android/Flytouch3/ChangeLog.txt (Same as version 3,4a,b,c,d plus)- added apn telephony db (should allow to save apns)- changed kernel to 3d (should fix battery stats issue)- added back talk app + g* misc apk- declare system hw gps capability back- added isofs.ko module (use busybox mount to loop mount iso )- /dev links added for loop devices- added different tun.ko module- added bluetooth drivers + Gscript to load drivers- added missing noatime on internal mmc- Windows Network Shared drives support (cifs) (use the app CifsManager for easy mounting)- NTFS drives support(use the "mount usb drives" Gscript to mount)- Gscript to mount usb drives (mostly useful for ntfs usb drives)- Added GScript to load the usb wifi sticks drivers Realtek 8192cu and RAL rt5370 (Load more drivers Gscript)- Added back gps-status, spareparts, filemanager- Issues of Apps installing to /local instead of sdcard- Speed improvements- Most Huawei 3G sticks support- Flash support for full screen videos (still requires a lot of cpu to work, but should work better and fullscreen for most videos, make sure you don't have other cpu eating apps running at the same time or it tends to be unstable)- fixed installation failed error -18 requiring to remove SD card for certain applications (Angry birds...)- backported 16GB tablet format partition fix for Market (refusing to install)- added tun.ko kernel module for certain VPNs- media scanning Off by default (use Gscript to activate it back, or use QuickPic for Pics and video browsing, and ccplayer for music, faster ! )- internal SD card free space is now at /mnt/sdcard and external SD1 is at /mnt/sdcard/sdcard1- ask before doing media scanning on SD card insertion- updated youtube app to 2.1.6- Better Keyboard 8 as default- added init.d structure call at boot time- updated framework and libs- Turned ethernet off and wifi on by default- added cpunotifyIssues:Unknown as yet.20110712 (CUSTOM ROM: Tim: Release 5a. Based off the 20110530 firmware)Link: http://public.timduru.org/Android/Flytouch3/TimV5/20110712_Tim5a.zipTested by: UntestedFixes: http://public.timduru.org/Android/Flytouch3/ChangeLog.txt (Same as previous versions plus:)- Gscript to fix newer models 2Mp camera issue.- Patched libigps.so for quicker gps location fix after 1st fix.- Merged back the official firmware 20110530 useful modifications- Updated framework & optimizations- Updated appsMapsBetterKeyboard DolphinBrowserLogViewer- Vpn fix. (PPTP with or without encryption reported to work, OpenVPN most likely not working, please report.)- Zipaligned video player & ccplayer by FlanFinger- Deactivate MyPad application by default (Buggy to mount/unmount and see external medias)- Add GScript to reactivate MyPad application (better use FileManager, use MyPad at your own risk)- Settings.apk with more features unlocked by UncleRus- Add TtsService.apk back- Add NetworkLocation.apk----------------------------------------------------Choose the firmware that fixes the issues that most annoy you!REMEMBER: Back up your device before doing any firmware updates!Ensure it is a Flytouch2 v2 / Superpad II that you actually have: Most of us have pad Model: Disco. These firmwares DO NOT WORK with Model: SAWEE10 OR P041 (Commonly referred to as jpad and usually comes in a Superpad III Box) There is a totally different firmware set and method for updating the SAWEE clones. Please read this thread:Fake Flytouch 3 Guide: Superpad III, Jpad Sawee10 Beware - Android ForumsHOW TO INSTALL: For questions and instructions on how to install firmware updates, please refer to these threads:Firmware update method for SuperPAD II Warning about firmware: Avoid flashing 'bootloader-discovery' to your device
I found this from the video for which I am giving you the link. It is a bit long winded but he gets you to the Development which enables the debugging.
  1. www.[B]youtube.com[/B]/watch?v=Y_mVnzd7w04 Good Luck
Hello Guys this ROM work for this Tablet:
Especifications:
Tablet Infotmic X220 ARM11 1Ghz CPU
Model Number: Sawee10
Android Version: 2.2 V21:#3925
Baseband Version: Unknown
Kernel Version: 2.6.32.9
Infotm-sqa@infotm-sqa-desktop #82
Build Number: FRF85B
10.2" INCHS, 2 TF cards and 2 USB Ports
Thank u
