Follow these steps but when you get to step #2 it tricky
STEP 1
-Download the zip file: gentouch78patchv3-Lincs.zip
These are the files you will use IN PLACE of Augen's gentouch78patchv3.zip files. This patch includes AUGEN's update in addition to ClockWork Recovery. FOLLOW Augen's instructions (PDF document), using the files contained in this zip
You may view your device to see the enhancements made by Augen's 8/19/2010 software patch before you continue to STEP 2. You may notice missing or non working Google Apps. Step 2 will restore the Google applications.
STEP 2 - Home Key must be pressed in to start the Clockwork Recovery [Home] [Search] [Memory] to scroll around in Clockwork screen
-Download bootimg-su-googleapps-hosts-pirate.update3.zip. Copy this zip to the SDcard. No need to rename this file as it can be installed AS IS.
-Power down the device
-Boot into Clockwork Recovery (holding down the HOME button while powering up the device)
-Select install zip from sdcard
-Select choose zip from sdcard (it may take a min or so for clockwork to mount your sdcard so if it says no sdcard present just wait and try again)
-Select the zip file you want to flash.
-Once completed reboot
-Enjoy the new features!
Note this comes from the author, I am not the author of these files.
OK so I did finally get the patch installed from an XP machine..... Never got the Win 7 Machine to do it but all is well that ends well right? Thanks CPG716 and TIPSTIR! But now I am having a problem with "step 2" Did you drag the zip file from the windows machine via the USB cable or did you pop out the SD card and do it that way? I dragged the file to the card and it shows up in windows but not in ES File Explorer.... also when I view the card in windows the only folder I see is the DCIM folder. When I try popping out the card windows doesn't recognize it at all...... any Ideas?
OK also in windows it looks like 3 sifferent drives but I can only access one. The only one I can access looks like a 2GB partition. I am using an 8GB Scan Disk card. I formatted the drive I could access, dragged the zip over to it again and tried to follow the steps in "step 2" but Clockwork says it can not mount /sdcard...
Got it..... had to mount usb in clockwork and drag it over then.... not too shabby... although root explorer is definitely not working.... I do love the pirate robot on boot... Thanks again for the help!
no i did not, but now i am begining to suspect my home button may be faultly. because now that i applied both the v3 update and the pirate patch, i am having trouble getting back into recovery.
Did you use USB Stick or Micro SD card ?? , so you tried to mount /sdcard and it failed to recognize your sd card, then when you used mount USB it worked, please explain as I have hard time getting my GT78 to recognize my micro SD card from within GT78 or from Clockwork as well
I have found that my home key tends to need a pretty heavy finger pressure in order to get into recovery.
whether its faulty or just poor design I duno
