Hannspree SN10T1 deleting problems
simonenicol
My husband and I have just both bought Hannspree Handpads. We are very pleased with them but on both pads we cannot delete programs and icons which we have installed that we no longer need. When dragging the icon to the "Put away" the icon springs back to its oridginal position. We have both spent hours trying to figure this out. Please please can you help. Thanks for any help.
Did you find an answer to your problem, I am struggling with the same issue?
Have now found how to delete. Click on star just before the address bar having brought a page up ie. Google. Then click on home screen (list of icons will drop down ) click on strar at the end of icon discription andclick remove when it appears . Return to home screen icon should be gone. If not click on the icon you want to remove then click on the star at the end of the www address untick the box 'add icon to home screen'.Click on save then on remove from pop up screen. Icon should now be gone from home screen.
