Help me fix my 10" crap
I think mine swhitches the HOME and Vol- buttons. If I press Power+Back+Vol- it takes me to recovery, but after that it says "No recovery image is found, try recover from SD"
I never managed to connect this pad with my PC
Okay... that means the zSYS is not there. Different makers like to make their button sequences... different. :rolleyes:
It IS possible to do the SD card routine with just the zSYS.img file, if I recall correctly... you could try that if you have one from the version that you got working the most recent time...
Certainly another option worth looking into! :D
Hi: My case is exactly as angelov86 but I have 2 clones with board DK1031 and CPU InfoTMIC210.
Model
( Blank)
Android Version
2.3.3
Baseband
Unknown
Kernel version
2.6.35.7-infoTM
root@ice#126
Build number
GRI40
I Tried to update firmare to Tims 6a with no luck using this 2 different methods
2 files on the root of the 705M SD Card
2 files inside a Folder called android.
(files) firmware2 &firmware-discovery.
A Friend of mine tried on 1 of my tablets a folder called android and 5 files inside. Now
that tablet is always with the green android logo.
I noticed that the one that works has the ubuntu logo on boot.
I cloned the internal 16GB SD from the working one with Roadkill and the working tablet work with both Internal SD card. but the bricked one don't.
anyway to fix this?
and anyway to update to a better rom like tims6a.
Thanks in advance.
Im trying to get my DK1031L BACK to 2.3.3 (GRI40)...
I dont like you much. :p
j/k :D
