Help! Need the firmware on Ematic FunTab FTABC!
Tany
Jul 22, 2014
It turned out that he does not boot, it needs OS installation.
But to make a return to the manufacturer I can't because I live in another country, but could carry in repair here, only need the firmware for help! Can someone has firmware on Ematic FunTab FTABC?
Hi Tany, congratulations on your Ematic FunTab and welcome to the forum. Glad you decided to join us here at Android Tablets. I'd suggest you try a factory reset of your tablet. Check http://www.androidtablets.net/forum/android-tablet-q/62022-how-do-i-factory-reset-my-tablet.html.
If there are no instructions for your tablet, try some of the methods for other tablets. One of them will probably work and you won't hurt anything by trying as long as the tablet has a good charge.
Thanks for the help, but I have tried everything, and the manufacturer has informed me that in this model, a hard reset is not done!! I despair - what do I do with it?:confused:
Several times he was involved, but the first time I managed to delete 3 games and it is off, and the second time he was discharged battery - he wrote "connect the charger" and turned off.
How else one can help to turn - to make hard reset can only be set from the menu Android.
