iiDiabolusZz
- Nov 9, 2012
- 441
- 113
Heres the V2 firmware http://file2.mydrivers.com/ondata/download/driver/oamp3/V712D/V712D-V2_v1.5.5.zip
Try flashing it could solve your issues. When you rooted did you uninstall the chinese apps like you said with Titanium??
I prefer to do one clean install, takes out all the unwanted apps and then root and your done, then dont have to keep messing about, as for your tablet not having physical volume buttons you use the home key to go down the menu selection and power to select. My walk-through is on here just use the firmware file above, hope this helps.
**Just read back through the post and see you did remove chinese apps yourself, you could of removed something you shouldnt have resulting in your problems, having root access is great but you need to be 110% sure you no what your removing before you do **
My advice would be start again, fresh firmware and root.
