Luckily, I didn't have such a nightmare with mine. There are 2 little tabs sticking up.. I sat the tablet face down on my desk, then took both of my thumbs one on each tab, and pressed up on them. Kinda like taking the back off of a remote to change the batteries.. It should slide off. I've heard others who used an exacto knife to pop it off.. Sorry you're having such a problem with it.
Best of luck, let us know when you get it off.
It is ridiculous that this is so poorly documented. I did not know about the thumb tabs and it was nerve wracking to take the cover off. Even using tabs, a rigid plastic snap together design is not intended for frequent use IMO. Especially one that is covered by most decent cases. I have pretty much accepted that it is a system upgrade and not general purpose removable media. I use a dongle and USB drive for that. OTOH, you really can't set up much on the system to use all that extra storage automatically.
