thecaringkind
- Apr 19, 2011
- 5
- 0
Hi all. I loaded the 'experimental release' or most recent version of the Vegan ROM and ran it for a little while with no problems at all. Even loaded a bunch of apps from the Amazon App Store and they seemed to work fine. I loaded SetCPU also as I would like to overclock my gTab, and I selected the radio box for the overclock settings to be applied 'on boot'. I shut the tab down and upon trying to turn it on and boot, I get the Viewsonic screen and then the Vegan-Tab loading animation which cycles a few times and then...NOTHING. It cannot load the desktop. I have clockwork recovery installed and can access that. What should I do? Flash the ROM or a new one all over again? Thanks in advance!
