help with coby 8042
Status
Not open for further replies.
darscute03
11
Hello guys i got a problem so its started when i flashed my coby 8042 then the touchscreen didnt work so i tried to look for solutions , ended up on 7042 mv_ bootloader so i accidentally flashed it with my 8042 and now the screen size, touchscreen has a issue. Can someone help me i got backup of dump file with tgz but i tried root utility restore not working can anyone help me thanks in advance. :)
please close this thread already fixed the issue thanks again with vampireinfo and traveller :)
Will great if you could share the info and any link that how you solved the problem as it could be reference for others in future.
After i fixed the issue i already created the thread so that i can help people with windows based os. So that they can use adb shell easily without downloading large files that is not needed. :)
here http://www.androidtablets.net/forum...store-using-windows-based-os-tested-win7.html
Sorry if i need to create another thread i just want people to see the post quickly and help them: )
Great and thanks for the info.
As requested. Thread Closed
Status
