Help with Coby Kryos MID 7125
sparker781
Hey All thanks for stopping by.
Was recently given a Coby Kryos MID 7125 Tablet. I did a factory reset to start over from scratch. Is it possible to get it up to speed in terms of installing the Play Store and some other apps like Facebook which I know I can get once I install the Play store.
Should I try and root the device for better success?
Any and all help is appreciated
Spider
15,781
1,812
Hi, congratulations on your new to you Coby 7125 and welcome to the forum. Nice to have you as a member of Android Tablets. I'm moving your thread to the Coby Generation 2 forum for you, where more people are likely to join the discussion and try to help you. Good luck!
