help with flash adobe
cjsteury
How do i get Flash back up and running in iconia tab a500 w latest os update and w browser v 4.. the latest firmware just killed flash for all apps and websites. using flah ver 11.1
help?
help?
Welcome to the forum
The question has been asked so many times I added a link in my signature that may help. Many have had that work, (11.1.x) but some have not.
its interesting that this issue is so common cause i find it very difficult to locate the threads to help and the flash link does not work its exactly the same issue totally dead.
Not certain if you meant the suggestions/instructions in the link did not work or the link did not work. If you used the instructions, what happened? Normally Flash should have remained active as most people with the problem had Jelly Bean and had to uninstall Flash for some reason and couldn't find it again on the Store, since they took it off.
If trying to install it failed and you don't have JB I'm thinking something else in your update got corrupted that happened to also kill Flash. If that's the case the solution may be a factory reset.
i dont know what JB is. i have an iconia tablet - however the file from Dawnstar works great! thanks!
JB is "Jellybean" - Version 4.1 of the Android OS.
