Help with Settings
Roberta427
Hi, Can someone explain how I access the settings on my tablet or provide a link that will explain how I change them? Thanks.
leeshor
6,328
1,036
There should be a settings icon in your app drawer, accessible using the icon in the upper right corner of the screen. There are a lot of settings there, some tablet specific and some Android version specific. You'll need to give us some sort of idea what you are wanting to do.
Roberta427
Thanks. The first thing I'd like to do is change the touch screen settings.Where are they located?
leeshor
6,328
1,036
Knowing what touchscreen settings would help but you should be able to find the options you have under display. If not there then it may not be available.
Douvie
1,030
71
Most probably the keyboard settings. Like turning off the clicking keyboard, or the vibrating keyboard. You find them under the display settings or under languages.
