Nope. It's the SD Card which has put in micro sd slot'sdcard' is your internal storage when most of your apps data is stored.
there is no directory as such sdcard2 in my NCYou will see a 'sdcard' and 'sdcard2' directory
Expected. It should appear.If you don't believe me copy something to your nook using samba and look at the 'sdcard' directory. You will see your file.
Nope. IMO its not normal. It should be seen under SDCARD directory only.Now take your MicroSD card out and put it in your PC, put a random folder on it. Put it back in your nook and go to the 'sdcard2' directory and you will see that file.
Ok let me try to say it instead of show it...
By default, when you open Samba, you see your internal 'sdcard' directory on your internal storage. Thats why the username is 'sdcard' when setting up Samba.
By hitting the " \ " you go to the root directory of you tablet. You will see a 'sdcard' and 'sdcard2' directory.
'sdcard2' is the MicroSD card that you inserted into the device.
If you don't believe me copy something to your nook using samba and look at the 'sdcard' directory. You will see your file. Now take your MicroSD card out and put it in your PC, put a random folder on it. Put it back in your nook and go to the 'sdcard2' directory and you will see that file.
Are we clear now?
The problem is that Samba acts differently per device and I did not see that before. Also ES File Explorer does as well.
Samba on nook puts it on the sdcard.
Samba for other devices puts it on internal sdcard storage.
I say 'Internal sdcard' because ES File Explorer just calls it 'sdcard' and 'sdcard2'
Ugh... forget it. You don't understand what I mean. I need to get a SS program so I can better show you. But this is a nook thread so I'm done with gtab stuff.
